Hi
What is V-model crankshaft's diameter tolerance? I mean the diameter tolerances for the crankshaft's bearing surfaces.
If a bearing surface is corroded and should be ground and polished is there oversized roller bearings for sale anywhere to allow a smaller shaft diameter?
Thanks, JJ
Thanks, JJ
