Filling oil - Yamaha F100 Outboard gear
  • Filling oil - Yamaha F100 Outboard gear
    Hi,
    does any of you know the easiest way to fill oil on the gear on the outboard engine ?
    I can see that above you have the level screw, and below you have the empty screw. Somebody are talking about filling the oil from the hole at the empty screw.....
    markle
    Yep. Just pump it in from the bottom until it comes out the top.You can buy a pump that screws into top of the lube bottle. Might need yammy lower unit thread adapter.Check the old stuff for water and-or chips!
      Easy job once you do it. Go to: Bogueinletnc.com/yamaha for step by step instructions with photos on this and several other maintenance/repair procedures. Good Luck!
        Hi,
        thanks very muck for your help - i veru much appreciate your assistance.
        Do you know the part number for the unit to mount on the empty hole ? (to pump oil into the gearbox) - otherwise is there anotwer way to avoid that the oil is running out when pumping new oil ?
