Trim Sensor "Stop" Part Number
  • Trim Sensor "Stop" Part Number
    Need the part number for the 1997 150 trim sensor "stop"....not sure what it's called. It's not the sensor itself but is the piece that clamps around the shaft and has the lever that the sensor activates on.
    Tom P in Virginia Beach, VA
    1997 Yamaha S150TXRV on
    1997 Scout 192 SportFish
    The trim cam is number 1 in this diagram Yamaha Outboard Parts 1997 S150TXRV BRACKET 2 Diagram
      Thanks. Just ordered it from you.
        Received cam. Apparently it is an upgraded piece. Came with cam and screw separately.
        How do I determine the proper position on the shaft? (from a rotational standpoint).
        Is there anything that needs to be re-set etc? with the digital gages?
          There is a detent pin on inside of trim cam thats aligns in hole on tilt tube.
            Thanks....got it working properly now.
