G'day to the international Yamaha family . . .
I recently bought a 30 DMH 2002 Yamaha outboard, and have nearly got it sorted out.
I need help with the last problem . . . there is an intermittent knocking/clunking sound in the engine. It is a solid sound, like the driveshaft is trying to jump back into spline mesh.( Its very hard to describe a noise !)
I originally thought it might be the pinion bearing at the bottom of the driveshaft, but I discounted that by taking off the lower unit . . . and it still made the noise.
When I run it on the muffs, it only seemed to make the sound when it was quickly decreasing revs, rather than building revs. It does it in neutral and forward gear as well.
I took it for a short run yesterday, and found the noise to be more evident under normal load. I couldn't get past 1500 or so rpm without it clunking. It would rev smoothly for 10 or 20 seconds, but when I applied a little more power, it would clunk. It seemed that the clunk even led to the motor stalling a couple of times.
It has got me stumped. The motor will start easily and idle like a kitten all day long.
Any ideas greatly appreciated. I have been told to look at the flywheel and check it's correctly tightened.
I'm looking forward to the long Australian summer ahead . . and would love to have this Yammy running like it should !
Thanks again . . .
Thanks again . . .
