just changed Replacement Gas Filter/separators ...
  • just changed Replacement Gas Filter/separators ...
    just changed Gas Filter/separators ... now i got engine started and now running rough ,,
    the engine has not been run in a time 3 months the plugs were kinda new would the filter have anything to do with the engine running rough richard r
    Did you have fuel stabilizer in your fuel during 3 month lay-up? If not, then most likely fuel degraded and fouled your system. The fuel/water seperator doesn't eliminate the need for fuel stabilizer. Good Luck!
      What year and model ?
      What's the year and model of your motor? If it's one of the old carb motors, and you let it sit for months at a time without running it, the carb jets and passages get clogged up and will have to be cleaned out. Don't let a carbed motor sit with fuel in the carbs for more than a couple weeks (at most) without running the motor. You're asking for trouble.
      - Mike
        thank guys
        Its a 1996 200 saltwater 2 I ran it today sitting the drive way sonud like missing cylder so i have to get new spark plues i put 5 gallon of good gas in it with gas treatment there was very little gas in it before this .suck started rite up I sprayed carb cleaner in the carbs before i started it .but have not put it in the water yet anything else i can do???
        richard R
          - Mike
          how would i clean jets just in case???
