I have a 1985 115etlk 2 stroke with an occasional no start-no spark. The engine cranks fine but will not fire. Pulled wires and checked for spark- no spark. If the engine sits for a short period of time it will fire right up. I have tried disconnecting the engine kill wire at cdi- no difference. I suspect either a stator or cdi. Does anyone have the pinout and resistance specs for the stator and pulsor coils?
115 2 stroke no spark
It could be a bad stator or CDI unit. You would need a peak reading volt meter to test output voltage of ignition system.
160 volts between brown and red charge coil leads.
45 volts between blue and black/red charge coil leads
125 volts between black/white and black CDI output leads.
2.5 volts white/red and white/yellow pulsor coil leads
2.5 volts white/black and white/green pulsor coil leads
Â
