I am in the process of closing a deal on a slightly used 2006 4 stroke. I am ending a long and well served Johnson 60 engine on my pontoon boat. I am trying to figure out how much the conversion will cost me. I need a new throttle/shift control unit and harnes to engine. I can't find what I need in the parts list. Would like to have the safety kill switch (lanyard) and key start all in the control unit. Does Yamaha have this? Also would like to take advantage of the sensors avaiable on the engine on the dash, tach, trim. water flow or temperature gage etc. I will also be changing it from a hydraulic steering to the standard manual system. The previous owner will be keeping the con*****er and hydraulic steering. Of course the shift and throttle cables will have to be changed unless there is an adapter for the cable ends. Can anyone give me a list of options and part numbers and where I can look these up for pricing. Thanks in advance for any help you can offer me. I hope to close the deal early next week, 9/21/09 to 9/23/09.
PS it is a high thrust version of the T60 TLR if this makes any difference. Also the length of harness needed is about 12 feet.
