Just installed a new Yamaha Fuel Management Gauge connected to twin HPDIs. When I turn it on, the self check works and all segments light. The mode switch works fine. I don't see any response to the set switch. The P & S letters don't show after the self test (they do during self-test). Per manual, it is supposed to switch from P to S to PS by hitting set switch. Nothing happens when I hit the set switch. Have checked the +12V, 12V keyed and ground and they are good. I am not using the tach inputs to the gauge. I have my GPS connected to the gauge. Settings set for GPH and GPS. Fuel consumption of 0 is displayed when on the water hose. Will run it in the water tomorrow.
Am I supposed to do something after turning the system on to bring up the PS display? Thanks for the help.
