'06,50HP 2 stroke Hard Starting after Sit
  • '06,50HP 2 stroke Hard Starting after Sit
    Recently my '06, 50 HP 2 stroke has some difficulty starting after sitting for a week or so.
    The starter engaes briefly (to about 500 RPM) and then kicks out---no start
    Many Repeated efforts, do the same thing, then finally starts at a low RPM( about 800) warms up then at 1100 or so, then all is OK.
    Makes no difference if the bulb is soft or rock hard .
    So, what's going on
    Thanks in advance....
    Make sure the red lever on your prime start system is in the correct position. There is a sticker on the engine that shows this. The lever has three positions Normal, Emergency, and closed. Full counter clockwise is the "Normal" position.
      I checked the lever it was in the correct place.
      Load tested battery , it was low. charged battery. Good start and run.
      Thanks for the reply!!
