removing gears
  • removing gears
    what do I have to do to get the gears out of the lower unit?.
    1987 70 hp yamaha
    It will require some special tools and a service manual. Remove bearing carrier by removing cover nut(requires special tool) and pull carrier with a puller then you can remove shift shaft, prop shaft and drive shaft.
      how much is the tool?
      and do you have it?
      thanks
      Ron
        Call boats.net at 1-877-408-1499 and they can give the price and availabilty on tools.
