Run 1988 200 on stand
  • Run 1988 200 on stand
    To do this without a switch panel I know the brown wire will crank it but what about ignition power? Will I have to use choke to kill it?
    Thanks///Bruce
    Yes it will not shut off unless you have a switch hooked up to it.
      Will it start and run cranking with brown wire or do I need to power yellow wire for spark?
        The carb models will run by jumping starter solenoid only.
          Starter solenoid to yellow wire?
