1994 130 Oil Alarm
  • 1994 130 Oil Alarm
    Help.
    I am getting an intermitant oil alarm from time to time. Always happens underway at all diff RPMs. All 3 bars on tach blink and alarm goes off. When it does I power down turn the key off...and start again...everything is fine. I have tested the float swith on the outboard tank and it seems to work finr. I have looked at wires shaked and pulled em all. No alarm.
    Any ideas?
    I have tested the transfer circut and that works.
    I have tested both float switches and they work.
    The trim switch works.
    The manual pump circut works.
      Check the inline fuses on engine, fuse may be fitting in fuse holder too loosely.
        Hello my freinds, i have the same problem.My question is where is the fuse located..
          Mako...how long have you had this problem...how does it go down?
          Boats-I cleaned up the main fuse and connections. Went out last night for about 2 hrs with no horn....going again today....well see. Oil system still working fine otherwise.
            No horn again on my second trip. HAd the boat going all RPMs in calm seas. crossing my fingers here.
