The 9.9 stalls, usually after running a while. It is like the key was turned off. It usually starts right back up. I also get changes in RPM with no change in throttle. Sometimes it starts chugging and then starts running normally again.
I have rebuilt the carborator and soaked in carb cleaning solution. I have installed a new fuel pump, changed fuel lines and put in a new fuel tank (the vent is open). The fuel is new and I filter it during refueling. The filter on the engine is new and I have checked it for plugging.
I have heard that a bad oil pressure switch can initiate engine RPM changes. Could this be the cause? Would this shut the engine down?
I really need some advice as I can't trust using the motor any more. Any other ideas I can try? I have had the engine in twice and they don't seem to duplicate the issues.
