I'm running a 1988 Yamaha ProV150 and am having trouble with high rpm power. It seems to cut out around 4800 rpm and surge. I've had two dealers look at it and neither was able to fix the problem (though they both charged us for the labor and claim they rebuilt the carbs). I've run a compression test and all cylinders check out fine. I bought a new coil and lake tested it while replacing each of the six coils in order and no change. By pulling the plug wires off one at a time and running on the water, I've determined that the problem is in the bottom two cylinders and most likely the bottom carburetor. I pulled apart the lower carb and found no obvious problem, but I have a question regarding the needle and seat.
At one time, a Yamaha service tech said that there had been some problems with these engines getting debris behind the needle and seat where it couldn't escape and causing the sort of problem I'm having. He said that there is a retrofit kit that allows drilling a hole behind the seat to flush out debris and then plugging it with a screw plug. Does anyone know anything about this? I'd also appreciate any other suggestions.
Thanks in advance!
Thanks in advance!
