Ok, long story short. boat ('72 Hydrodyne 18') and motor not used since 2003. Boat needed a new transom, etc.... Anyways, got the engine running again and on the boat which used to shoot out of the water and top off about 60 MPH. Now it goes maybe 35 and no zip at all. it runs smooth, but not strong. Cables are "tight", but I remember this boat just flying with this engine. I had a recommendation of using Sea Foam fuel additive to get the gunk out as a remedy to cleam the varnished carbs. Good idea? Bad Idea? Any help appreciated. BTW, gaskets on head were replaced (one was leaking ) and compression showed all about 110, one cylinder at 105, so all is good there?
Keegan
Keegan
. I did put some new plugs in it, have not run it yet, but i would think a good carb cleaning is in order.
