2001 F115 Throttle joint link rod
  • 2001 F115 Throttle joint link rod
    How do you remove the throttle joint link rod from the control unit? Does it just pull off the Control Unit or does it have a locking pin? Also do you have to remove the intake silencer and intake assemble to get to the fuel vapor separator?
    It does pop off the throttle body and yes the air silencer does have to be removed to get to VST.
