I have a 200 HPDI that accelerates fine out of the hole up to 3500 rpm's after that the more throttle just flattens it out, pull the throttle back some and it picks up. there is 18 hrs on all new racor primary, paper primary in the plastic bowl on the block, yellow strainer on the vst, and metal inline from vst to high pressure pump. No codes and the software states "normal" on fuel pressure. I put a vacuum gauge just before the plastic filter on the block and get no vacuum thru the rpm range. Then a pressure gauge between the lift pumps and the vst with a reading at low rpm 3-3.5 psi at wot 5 psi. Then tested the output at the vst is 51 psi. I am thinking high pressure pump but that would mean both the pump and sensor would be bad because the software is saying "normal"
Any incite would be helpful.
Thank You
Thank You
