Rectifier for 20 hp 2 stroke
  • Rectifier for 20 hp 2 stroke
    Hi,
    I've got a second yamaha outboard that I'd also like to purchase a rectifier for as well as a replacement part for the "bolt" that allows one to tighten/loosen the resistance on the throttle at the tiller arm.
    Model is as follows:
    20MSHW
    I believe it is a late 1990's model
    I'd like to order the part for this engine and the rectifier for the F15 engine at the same time. I'd also like to know what the delivery time is to Tampa once the order is placed.
    Thanks for your help.
    I also need a carb rebuild kit for this engine.
      The rectifier kit is part number 6G1-81970-00-00.
      The bolt number 20 in this diagram Yamaha Outboard Parts 1997 20MSHV BRACKET 1 Diagram
      You can call 877-408-1499 extension 200 for the delivery time to you.
