i have a 26 foot sundancer tritoon with a 1997 yamaha prov 150 on it.
i banged my prop and want to know how much play there should be in the shaft.i put a dial indicator on the shaft and rotated it by hand,it had .0006 play at the end and .0003 play up close to the seal area.
it runs around 5400 rpm on top end. im worried the seal will give out and leak all the lube out, and we know what happens after that.i have replaced the prop and can not feel any vibration and there is no oil or water leak on the lower unit.should i keep an eye on it or change it ???
