noob carb questions (cont)
  • noob carb questions (cont)
    On my 1991 Yamaha 70HP, I tore apart the 3 carbs and cleaned the jets and passage ways and checked my carb floats. I have 2 questions about carburetors:
    1) My motor runs better at idle with choke open 1/2 way. The RPMs are slightly higher and runs smoother. If the choke is closed, it runs a little rougher for 5 minutes before it completely cuts out. Fuel Pump is still hard.
    2) Unburned gas spits out the exhaust. No idea what it could be.
    It was frustrating to spend 5 hours tearing apart carbs for no good results. Hoping to get some help here.
    If it will stay running with choke closed then you still have passages or jets plugged up in carbs.
