I have a used 2004 25 hp four stroke, manual start, tiller that I recently purchased knowing that it would need some work. Here is what has been done thus far:
by me:
New plugs
New inline fuel filter
At marine service:
Oil change in head and lower unit
New impeller
New lower unit gaskets/seals
Carbs cleaned
Compression is apparently good.
Mechanic says there are indicators that motor was run hot in the past.
Motor starts on second pull every time, idles smooth, but runs rough when warmed up. I have not felt if water from 'pee hole' is warm or not since it's been at the shop for a month. I got no straight answer on what they think should be done next. It has been four days since they even looked at it, and I'm just going to go get it tomorrow and try another mechanic. Thought it worth a shot to post here and perhaps get some ideas to try before spending more on labor hours.
With everything we have done to it, why wouldn't the darn thing just run like a sewing machine when warmed up? Thanks any ideas you can throw my way.
by me:
New plugs
At marine service:
New impeller
Carbs cleaned
