Hello,
I'm installing a set of Volvo QL tabs and have run into a little snag. I need to connect a wire from the control panel to a a power source that is con*****ed by the ignition switch. I looked at the back of the switch and first there is not much slack or room and also there are more than a few wires back there so I don't know which would be the "run" wire. Does anyone have a clue where I can find switched power? It is a 2004 Yamaha F200 on an Aquasport 215 Osprey Sport DC. I'm starting to think there should be a terminal somewhere on the motor I could run to. Any help would be appreciated.
Thanks,
Mike
Thanks,
Mike
