I just changed my impeller and thermostat, and my motor is over heating.
Buzzer was going off and couldn’t run above 2000 rpm prior to the change, but the head didn’t feel that warm when the buzzer was sounding I could touch the head and it wasn’t that hot.
The weird thing is the head quite a bit feels hotter now than before I changed things, also the tell tale stream doesn’t seem as strong.
When I changed the impeller I rotated the shaft clockwise, also applied some lube to the pump housing and it went to gather real easy.
I didn’t change the poppit valve, but it looks clean.
After returning from the river I took the thermostat housing off and hooked up the hose to see if I was getting good water flow, a couple seconds after starting the motor the water started flowing but seemed to be pretty warm.
I checked the plugs and they look good no signs of water in the cylinders.
So any ideas?
Jeff.
So any ideas?
Jeff.
