Hi - I've got twin 1999 250 saltwater series. My speed read out is 0MPH which means either I have a disconnect/kink/or salt blockage.
My problem is that my boat is in the water and water temp is 44degrees.
Is there any way to visually inspect or diagnose the pickup tube location from on the boat. Both engines have a tube coming up but I can not locate where on the housing it is picking up the water. If I could locate it I could try and insert a drillbit to clean it out.
Any advice or even better a picture showing where the pickup is located?
My service manual does not cover this anywhere in the lower unit section.
Also - would both engines be feeding the digital unit or just one?
Ed
Ed
