I'm adding a trim gauge to my 150, the boat had teleflex lido's so that is what I went with. I was told to connect the pink wire for the trim sender.
In the motor I find a lone pick wire that shows the correct Ohms and also a pink and black pair of which the pink shows the correct Ohms to operate the gauge. Both of these are have a connector that has a wire continue on to another location.
First which of these do I use and second after I open the connector do I just cap off the other unused end? Or do I need to splice "all 3" wires back together? All 3 being the 2 existing that are spliced at the connector and then my new 3rd wire to the gauge?
Last if one pink is for the sender what is the other for?
Hope that makes sense, Dave
