Connecting FMM to Furuno Navnet GPS
  • Connecting FMM to Furuno Navnet GPS
    Good evening,
    I am trying to connect Yamaha FMM with Furuno Navnet GPS. The follwoing excerpt if from Furuno customer service:
    "If DATA PORT 1 is used, you can use DATA 3. The cable is the same, part number “000-154-028”. Wire the WHITE and BARE shield wire to the FFM. The WHITE wire is the OUTPUT + and the Bare (shield) is the OUTPUT-, these wire into the FFM Input + and Input – respectively."
    So my questions are:
    1. FMM has a male S-Video connector for GPS connection. Of the 4 pins, which ones are "input +" and "input -"? I already have "000-154-028" and am trying to get it wired correctly.
    2. I am having a bit difficult time finding a S-Video FEMALE connector. Where can I find the female connector?
    Thanks for your time in advance.
    Regards,
    yhc
    It's the white wire
    6Y5-85721-F0-00 pricing
      white wire
      Do you mean the white wire from FMM is "input +"?
        Yes the white wire connects to GPS positive output lead.
          A bit of complication
          Good evening,
          I just came back from a few days of boating. Before I left on the trip I had conneted my FMM to GPS unit as stated above. When I checked them out separately they functioned fine. However when I turned them both on, FMM quit working...it actually would not turn on at all now. I checked the fuse near the battery and that was alright.
          Is there a reset switch for FMM that can be used? Do you have any suggestion on any trouble shooting tips other than replacing the whole unit?
          Regards,
          yhc
            Problem resolved
            The positive lead to FMM had come loose after a 70 mile road trip to the dock when I turned both units on! The problem is now resolved.
