The motor is an 07 70hp and seems to runs fine until you hit the magic number of 5600 then the motor drops almost instantly and sounds like it is starving for fuel or maybe spark. I’m at a total loss on this at this point. My carbs I have been told are clean and I do not run ethanol at all in the boat. Here is a laundry list of what has been done since this gremlin reared its head:
I have replaced the anti-siphon valve 3 times.
Replaced both filters inline and fuel/water twice
New plugs
New primer bulb
Carbs re-synched and linkage adjusted
This has the mechanic scratching his head as well. He has said with the boat running he cannot find this problem or diagnose it as everything checks out just fine (fuel flow etc.) but this problem seems to persist. It only seems to happen once I get over 5500 which for me is very rare but none the less it needs to be fixed before I have major trouble. I’m at a loss on this and wondering what else is left besides possible ignition, or maybe a carb problem that wasn’t seen. Any help or direction before I lose my mind would be greatly appreciated.
New plugs
New primer bulb
