Trim Gauges
  • Trim Gauges
    Hello. I have one digital Tach, where I can read the trim level, and also I have one analog trim gauge, is it possible to have both working on dash? From motor comes four wires , black, yelow, orange and pink and it is easy to conec to digital tach, however I do not Know how to conect to the analog gauge
    You would only be able to connect to 1 gauge, the connections would be same digital or analog unless analog gauge is other than a Yamaha gauge. The aftermarket gauges wont work unless it will work with a 3 wire trim sender.
