Hello i own a yamaha 85 AET. Does any one know the year of this engine? Also one day my outboard took about 1 hour to start and after heating the plugs cleaning the carb it eventually started and ran for about 5 minutes at about 3000rpm which is when it stopped and wouldnt start again. However the next day i went to stat it and it started and then cut out about 20 seconds later. The fuel is fine but there is no spark on any of the three cylinders. I have checked the key all was fine and i also have checked the killswitch which was fine. I still cannot find what is the problem there is a fuse on the outboard which is fine. Is there any specific wire i should check?
Thanks.
Thanks.
