I am replaceing my head gaskets and want to know if there is anything that I'm suppose to put on it before I put the new gaskets in, as far as like copper coat?
head gaskets
jb123:
What do you recommend to use to lube the bolts? After the head gasket installation, do you need to allow the gasket to adhere for a certain duration before running the motor? Lastly, is it necessary to perform a leak down test after the installation?
My apologies to johnharleymiller@aol.com, did not intend to hijack your post.
Use anti seize on head bolts. Once head bolts are properly torqued down gasket will seal. If you were having a compression problem before head gasket replacement then yes do a compression and leak down test.
Head gaskets , these days they get fitted dri plus the sealing surfaces need to be completely clean and dry as the new gaskets have the sealer coated both sides and in the right places, the sealer in a lot of cases is also heat sensitive . Once the motor has been run for a hour or so and completely cooled down its a good idea to re-torq the head as the gasket will have compressed minuitly and its possible to get a fraction of a turn from some of the head bolts . Be very accurate with the settings on your torq wrench . !!!
