G day is it possable to run two tanks through a manifold to 3/8 fittings to a single fuel flow sender and then to fitters ect to twin 115 Hp 2 stokes saltwater Obs and use the fuel management gauge as normal.
Fule Management Gauge
No when one tank runs empty motors would shut off regardless of how much fuel is in other tank.
Each engine should have it's own fuel delivery line from tank.
HI, You would have to run a fuel line from each tank to the supply side of the manifold,each fuel line would have to have a seperate shut off valve, run with one tank off and the other on. You should not have any problems doing it this way.
Dennis
