I have the Yamaha harness: 6Y5-83553-N0-00 gauge harness to use with my 2008 50 HP Yamaha 2-Stroke between the motor and my Teleflex guages.
1. Where does the harness plug into the motor? Is there one spot or do you have to crimp-in at differnet locations depending on what source you are after?
2. What color wire on the engine should I source for engine RPM ? (Where is it best to pick this up?)
3. What color wire on the engine should I source to let the ignition power the Teleflex guages internal lights ? (Where is it best to pick this up?)
4. I will check the instructions that came with the gauges also, but can you tell me if power for them comes from my fuse block or wether it is more typical to obtain power for them via the outboard engine...if so; what color wire should be sourced, and; in what location ?
Thanks!
Thanks!
