I have a 2001 HPDI that won't idle and "bogs down" when given gas in neutral. When in gear it runs poorly like it is fuel starved and surges when running or doesn't plane at all. I have run a direct line to fresh fuel, replaced fuel filters, injectors were sent away and inspected, new plugs, VST inspected last fall. Near the end of last season while running WOT it suddenly lost it's top end and ran about 800 less RPM's. Here's the YDTS results when I was able to get it into gear on the cuffs and keep it running. While at poor idle momentarily it shows #1 and #4 on only. Thought four cylinders were supposed to light up at idel? I know just enough about my motor to be dangerous and no dealers anywhere nearby. Any suggestions on where to look next? Thanks in advance if anyone has any thoughts. Any four strokes for Sale? Mark
p.s. The injectors were sent off after the 26 code and had run great up until the last several hours. Code was not reset
Save date March 01 2009
ECM No.: 68F8591A03
Diagnosis
Code Item Result Condition
13 Pulser coil Normal
14 Crank position sensor Normal
15 Water temp sensor Normal
18 Throttle position sensor Normal
19 Battery voltage Normal
22 Atmospheric press sensor Normal
23 Intake temp sensor Normal
25 Fuel press sensor Normal
26 Injector Normal
27 Water in fuel No
28 Shift position switch Normal
44 Engine stop lanyard switch Off
Diagnosis Record
Total hours of operation 457
Code Item Occurred
26 Injector 400.3
Engine Monitor
Monitor Item Result Unit
Engine speed 1575 r/min
Fuel pressure (5.0±0.8) 4.8 MPa
Fuel pressure (725±116) 696.07 psi
Atmospheric pressure 809.4 HPa
Atmospheric pressure 24 inHg
Ignition timing BTDC 4 deg
Battery voltage (12-16) 13.18 V
Oxygen sensor voltage (0-1.0) 0.88 V
TPS voltage (0.5-4.5) 0.83 V
Throttle valve opening (0-90) 6.8 deg
Fuel injection duration 0.92 ms
Water temperature (below 90) 54.5 °C
Water temperature (below 194) 130.1 °F
Intake temperature (below 70) 28 °C
Intake temperature (below 158) 82.4 °F
Electric oil pump Low
Firing of cylinder #1 Yes
Firing of cylinder #2 Yes
Firing of cylinder #3 Yes
Firing of cylinder #4 Yes
Firing of cylinder #5 Yes
Firing of cylinder #6 Yes
Starter switch OFF
Engine stop lanyard switch OFF
Over-rev control release lead OFF
Main switch ON
Shift position switch OFF
Water detection switch OFF
Oil level switch (remote tank) ON
Oil level switch1(engine tank) ON
Oil level switch2(engine tank) OFF
Oil level switch3(engine tank) OFF
Water temp switch (over heat) OFF
Dual engine system switch OFF
Data Logger[Engine operating hours according to engine speed]
Engine speed Time[h]
- 1000 r/min 205.5
1000 - 2000 r/min 70.9
2000 - 3000 r/min 2.6
3000 - 4000 r/min 59.5
4000 - 5000 r/min 101.8
5000 - 6000 r/min 16.9
6000 - 7000 r/min 0
Data Logger[Data comparison graph]
Engine speed[r/min] Fuel pressure (5.0±0.8)[MPa] Battery voltage (12-16)[V] Oxygen sensor voltage (0-1.0)[V] TPS voltage (0.5-4.5)[V] Water temperature (below 90)[°C]
700 4.65 12.52 0.02 1.72 50.5
450 4.61 12.96 0.19 0.86 49.3
350 4.49 12.74 0.72 0.86 54.5
600 4.65 12.67 0.65 1.84 57.5
400 4.3 9.3 0.08 0.88 20
900 4.72 11.43 0.26 1.84 24
450 4.57 12.16 0.27 0.8 40
350 4.65 12.16 0.07 0.78 49.7
950 4.76 12.16 0.1 0.8 51.5
350 4.57 12.08 0.29 0.8 52.3
350 4.49 12.82 0.03 0.88 62
600 4.65 11.35 0.1 0.84 38
400 4.61 12.16 0.15 0.82 42
ECM No.: 68F8591A03
Diagnosis
26 Injector Normal
27 Water in fuel No
Diagnosis Record
Code Item Occurred
26 Injector 400.3
Engine Monitor
Starter switch OFF
Main switch ON
- 1000 r/min 205.5
6000 - 7000 r/min 0
