Check to see if the grey wire(one on trim harness) is plugged up at engine in lower engine cowling.
installation and wiring diagrams for the Yamaha digital multifunction
Warning Sound
I have just rigged a 2000 0x66 and the warning buzzer goes off every time i turn the key on. The oil indicators on the digital gage flash for about a minute then go solid and the alarm goes off. Should this be happening every time? This is my third Yamaha and none of the others did this. Same controls.
Thanks David.
DMCCUMBERS@BELLSOUTH.NET
If the oil level in oil tank on engine is below lower line on tank alarm will activate until oil levels gets above line. If oil tank full then gauge harness is probably not connected correctly.
Yamaha 2000 80HP
I just installed a new gas tank and tried to hook up the sending unit to my 2000 80HP Yamaha 4stroke digital speedometer/clock/fuel gage/bat voltage gage. The fuel gage always was blinking before this, but everything else worked fine on that gauge. I tried hooking the black wire from the sending unit (before I installed it in the tank) to the battery and the red wire to the pink wire on the gauge. I could never get it to stop blinking. After a while I noticed the gauge was blank except for the light. I don't think I shorted anything, but who knows. I guess I would like to see a wiring diagram for the gauge so I can trouble shoot. I may have loosened a wire connection or maybe there is a fuse somewhere. If someone has a wiring diagram for this vintage of a digital gauge I would appreciate it. Thanks DaveG.
The fuel tank sender wire connects to white wire on speedo.
Yamaha 2000 80HP
Thanks so much for the print. My problem now is what I thought was a pink wire when I tested the sending unit was really the RED hot wire. I now have no voltage on it, so I either smoked the wire somewhere or hopefully more likely there is a fuse buried somewhere for this circuit. I don't really see any on the print, but maybe its in the control or back in the engine ? If you have any tips on where I should look for a fuse I would greatly appreciate it.
Thanks.. Dave G.
Fuel display works in reverse
I am trying to help a friend fix his fuel display (6Y5-83570-S5-00) which works in reverse. Eg. Shows full when empty etc. He doesnt have any documentation/wiring on the display. Some for sale sites for the display mention "Switch located on the back of the gauge simplifies fuel sender hook-up." What does this switch do? How should it be set? He also has a digital tacho unit also. A schematic would be helpful. Any thoughts welcomed.
Originally posted by DaveG View PostThanks so much for the print. My problem now is what I thought was a pink wire when I tested the sending unit was really the RED hot wire. I now have no voltage on it, so I either smoked the wire somewhere or hopefully more likely there is a fuse buried somewhere for this circuit. I don't really see any on the print, but maybe its in the control or back in the engine ? If you have any tips on where I should look for a fuse I would greatly appreciate it.
Thanks.. Dave G.
Originally posted by wendera View PostI am trying to help a friend fix his fuel display (6Y5-83570-S5-00) which works in reverse. Eg. Shows full when empty etc. He doesnt have any documentation/wiring on the display. Some for sale sites for the display mention "Switch located on the back of the gauge simplifies fuel sender hook-up." What does this switch do? How should it be set? He also has a digital tacho unit also. A schematic would be helpful. Any thoughts welcomed.
Originally posted by boats.net View PostNeed to check that fuel tank sender leads are connected correctly.
[ATTACH]293[/ATTACH]
[ATTACH]292[/ATTACH]
The boat has twin 60hp Yamahas and the speedo/fuel gauge only works from one motor. Is there a wiring diagram that shows how to connect up both motors to a single digital speedo/fuel gauge? At present, there are no isolation switches installed on the start batteries. Is there a schematic that shows a preferred power connection for two motors each with their own start batteries and isolation switches?
Thanks again
Paul
No the speedo should only be connected to one ignition switch.
Is it possible that someone could show me the schematics on how to connect a the digital multi-function (6yr-w0035-e2-00) guage to the 2004 Yamaha 25 hp 4stroke....am having difficult time, bought the harness today, and connection to meter is fine, but dont know how to connect on motor end.Thanks, any help is greatly appreciated as I am about to pull my hair out on this one....***!
Thanks again,
JerryLee
kuntrykandles1@aim.com
ÂÂÂÂÂ
