6Y8 multifunction meter
  • 6Y8 multifunction meter
    I cant get the fuel level indicator working.
    the manual refers to 3 types of level indicators.
    Yamaha, Europe and ABYC-US.
    what ohm values is standard for witch sensor?
    How is this instrument connected to the indicator?
    My indicator have about 180 Ohm with full tank.
    The tilt indicator does not work either.
    The engine is a -08 250 4stroke
    All boats in US use the ABYC-US setting.Connect the pink wire from fuel tank sender to pink wire on 6 pin harness that plugs into speedo. Connect black wire from 6 pin harness to fuel tank ground wire.
    If Trim indicator doesn't work check that the pink connectors on engine(on left side of engine at rear of engine pan) are connected to each other.
      Thanks for helping.
      The fuel level indicator i now working.
      But i cant find the pink wires for trimindicator.
      You say its located on left side at rear of engine pan.
      Left looked from boat or behind engine.
      Engine pan?
      Sorry that i dont undestand
      I norwegian and struggels a bit with technical english.
      Do you have som pics of location of this wires?
      SORRY
      I found it and its works perfectly
      THANKS ))))))
        I'm sorry, it's a pink wire with white connector.
          Thanks for helping
          It works just fin now
