Part number for 1995 multifunction tach
  • Part number for 1995 multifunction tach
    What would the part number be for 1995 multifunction tach? It's different from first design (late 80s, early 90s) but also different from the newer ones.
    1994-2005 use 6Y5-8350T-82-00 Multifunction Tachometer
      1995 Speed/fuel gauge
      How bout part num. for a speed/fuel gauge for a 1995 115 ? Wire diagram for tach an speed/fuel gauges would help also. Thanks. Boschfish
        Speedo is 6Y5-83570-S5-00
        6YRW0035F2_704 94-04 Wiring.pdf
          1995 speed/fuel gauge
          Thank's, Speed/fuel does't work at all. tach is readable barely over-heat,oil other functions don't work. Fuel sending unit works got a old gauge to work off it.I don't need to know speed,but over-heat I do.It has a seeding unit on each head bank can I jump both leads of one to activate the over-heat HORN ? Can only buy one right now low $ .If I had to buy one I'm thinken the tach.what do you think ??
