Is it possible to put 250 heads on a '99 v200tlrx. If so what would be the difference than just having a "shave" done. Customer sts compression is 101psi across the board give or take 3-4 psi. If your going to spend the money hopping it up the should "ring it" also. Which heads are compatiable? What say you high speed guru's???
200/250 heads
