Fuel Sender
  • Fuel Sender
    I am working in my new boat and I bought twin Yamaha 2002, 250 Outboard.
    They comes with digital gauges, two Tach gauges and one Speedo. My question is, I see on the gauges screen that can read fuel, but I do not see any sender to put on my fuel tank. Wich sender I will need? Would you give the part number?
    It uses the fuel sender that is in your tank, just connect pink wire from fuel tank sender to white wire on speedo.
      there is not any sender on my fuel tank. So, which sender I will need?
        You would need to take boat to a dealer to see if a sender could be installed in tank.
          I just installed a fuel sender on a new stainless tank for a new Yamaha digital speedo with fuel gauge. There was no need to use a Yamaha fuel sender, I used an off the shelf one, as the speedo has three different ohm ranges you can select to suit different senders.
