I have a 2002 Yamaha 150 VMAX that has made a noise like it was low on fluid since I got it last spring, but it seemed to work OK. I checked the fluid level added a small amount and it has been working until now.
Now the trim portion will raise until the tilt cylinder should take over and raise it up but it stops at that point and it sounds like the motor is bypassing.
I checked the fluid and it is full. I removed the unit tore it apart and can't find any bad O rings or any other problems.
Any ideas?
Any ideas?
