I have a 2003 25 HP 2 stroke enduro outboard at my home in in Belize. The engine has been perfect up until this week. The problem is it will randomely die while under power. It clearly feels like a lack of fuel issue. After it stops it restarts easily and runs again for awhile no problem. I replaced the fuel line and fuel tank thinking they were blocked and starving the engine for fuel. I also cleaned the engine fuel filter, the problem continued. Spark plugs are good. If it is run at idle or low speed it will go forever, the problem happens when the throttle is opened up. The more throttle applied the quicker it dies. I took off the fuel pump bolted to the engine and the diaphragms look OK but are stretched and some light shows through. I brought the pump back to the states with me as mechanics on my island are not very good.
I believe the weak diaphrams are root of the problem. Any other ideas?
