I have a 1992 Pro50 2-stroke that has a high voltage reading when at 4000 RPM or higher. My VHF radio has an alarm that sounds with a message displayed reading "High Battery." My Fishfinder/GPS is showing my battery at 15.3 volts when I'm at approximately 4000 RPM or higher. Some days it happens consistently and other days not at all. Otherwise, the voltage is at 12.3 volts at idle or 12.7-13.1 when at full throttle.
I recently changed out the CDI unit, Rectifier and NGK spark plugs. All wire connections are good and no damage on any cables. Battery is a group 29 that is less than a year old.
Any suggestions on what to check?
