am I winterized?
  • am I winterized?
    I have a 1990 Yamaha 85hp 2 stroke. I stabalized the fuel, fogged the cylinders and made sure the engine was straight up and down. Is there anything else I need to do for winterization? I do not have a manual but check several places and that is about all that is mentioned.
    i do the same as you,but i also drain and refill the lower unit with gear oil just to make sure there is no water in it to freeze, and bust the gear case.
      Thanks. I did forget to get the lower end.
