I'm hoping someone has the fix:
The problem is with my 2002 80 horse Yamaha motor, When the motor is trimmed to the highest position it will stick and not lower when using my tilt/trim button. The trim motor makes the noise but the motor stays upright. I have tried to assist the motor by pushing it down but no luck.. They only way to lower the moter is to loosen the screw.. (I'm very careful not to raise the motor all the way up when on the lake)
I would appreciate any help you could give me.. Thanks
Lastly, The screw is starting to show wear and is getting tough to loosen with a screw driver can that be replaced?
