1997 VMAX 175hp
  • 1997 VMAX 175hp
    Hi guys,
    is it possible to pull the crankcase cover off without pulling the flywheel?
    No both the top and bottom bearing housing will need to be removed from block.
      Thank you ,
      so does that mean I have to pull the powerhead in order to pull the crankcase cover?
        Yes it will have to be removed.
          Ok then,
          thank you for your help
