I bought a Telefex trim gauge and then a yamaha wire harness for my '08 Alumacraft Dominator w/ an '06 F150. I'm looking to install the gauge and was told to clip the gauge end of the harness off and connect the pink to the sender (S) on the gauge. I then tapped into the ground(black), Lights(Blue), Ignition (purple) under the console and hooked those up. I hooked the motor end of the harness to the matching connector in the motor that has 4 pink wires coming into it. Is that the right connector in the motor?
What do I do with the orange, grey and black wires left in the harness on the gauge end? I tried it with them just capped and the gauge goes to down (which the motor was) when I turn the key for about 5 seconds and then goes back to up even though the motor is down.
