I have a 1998 Yamaha 4 stroke F25TLRW that does not have water coming out the telltale port. Instead water pours out the front by the steering column. It doesn't overheat, but I know this is wrong. Can someone tell me what needs to be replaced? The motor is on a sailboat, in a marina, so in order to repair I will need to pull it out of the water (major PITA). Would it be wise to just replace the thermostat and put in a new water pump kit? Any hints on making this a trouble free repair will be appreciated. How difficult is it to pull the lower unit on this motor? I have worked on other outboards, but have not pulled this one apart before. BTW, this boat and motor used to be in saltwater and is now used in fresh water.
Thanks,
Pat
Thanks,
Pat
