Hey Guys,
New poster here. I tried a search but didn’t find my problem.
I have a 2000 150hp HPDI, model number Z150TXRY. A couple of times earlier this year I would be cruising along turning 3500 to 4000 rpm. The motor would seem to bog down and stop making power. This would go on for 20 to 30 seconds and then start running OK. Then my wife came back one day and told me the motor didn’t want to run when she put it in gear. After a few tries she got it to run and came back home. I went to use it again and it dies when put in gear. It also idles low, around 300 to 400 rpm. I played around and found that if I unplugged the Throttle Position Sensor I could get it to idle if I give it just a little throttle. So I was able to get it to a ramp and bring it home. When it ran without the TPS hooked up it would idle at 800 rpm when in gear.
Gas is good, plenty of oil. This seems like a computer problem to me. I have plenty of experience with cars but not so much on a high tech motor like this. If I can get a manual I think I will get the cable to read the computer.
I have three questions. 1) Where can I get a manual for this motor? 2) Does this seem like a TPS problem? 3) How do I measure the TPS to see if it’s bad.
Thanks Guys,
Robert
Thanks Guys,
Robert
