I have a 1999 225 v225tlrx. I can no longer properly adjust oil pump linkage due to wear in the lever that is on the throttle shaft. This lever is black plastic and doesnt show up on the online parts section.
Lever part number
No but that clip goes into the lever that I need. You can see it in that picture.It is on the end of the main throttle shaft. There is a small roll pin that goes through it and the hole in the lever is worn so there is alot of movement in it. It may not be serviced.
No the lever is not sold separate. It's unusual for it to be worn that much.
