Water pressure gauge acting strange
  • Water pressure gauge acting strange
    Why does my water pressure gauge fluctuate at low speed. When I am going 5mph, it will read 10psi or so, then fall to zero, then back to 10. I can see air in the line going back and forth when this happens. At higher speeds, it is steady. Motor is a 07' 50hp 4stk and yamaha gauge. It is peeing just fine, just curious about this.
    Thermostats or pressure control valve may be opening, as long as you maintain pressure at high speeds it's ok.
