Hello Everyone,
I'm having intermittent starting problem with 90hp yamaha and looking for any suggestions. Intermittently, when you turn the key, the gauges move, but does not crank. Sometimes, you can move the gear shift into and out of neutral, sometimes trimming the motor up/down a little, sometimes a prayer, will make it start??? The starting relay has been replaced. I have attempted to check with a meter and I believe the starter is good and I have 12V on one side of the starting relay when it would not crank. I am sure the neutral safety switch in the remote control assy is good. I just found out there is another neutral safety switch on the engine, (that's my next guess). I have been through wiring bundles and don't see any signs of corrosion. It seems as there have been a number of things that help for a day or two, then the problem comes back. Any thoughts or suggestions are appreciated.
Fred
Fred
